question about my new/old tube tester
Hi All. Last night I picked up this totally rebuilt Triplett 3413 tube tester and when I got home I saw on the scroll and in the manual that these tubes are not listed: the 6AS7, 2a3, 6080, or the 6c33c tubes.
Will this tester not test them???
Don't know for sure as I have Hickok testers, but seems it should, as it at least has a 6 volt heater setting. Looks like it has a 2.5V filament setting. You might have to scour internet for the proper settings and test results.
Will it test a 6A3 or 6B4G? If so, use 2.5 volts for a 2A3 instead of 6v. For 6AS7/6080s you will have to figure out the pin connections for the lever switches. And it's a very low gain tube with low Ip. Forget about that 6C33C monstrosity. There is no socket for it and the filament current exceeds the tester's capacity.
