I have an old stereo receiver which has two FETs in preamplifier stage, they are 2SK117 and probably they doesn't work. I bought new 2sk117, but what I wish to know; original FET was 2sk117 GR and I have new 2SK117Y. The different between those two FETs is in IDSS,
Y has 1.2~3.0 mA, GR has 2.6~6.5 mA, BL has 6~14 mA.
So my question is, can I use this 2SK117 Y instead 2SK117 GR (Service manual recommended to use 2SK117 GR or BL). What will be if I use that 2SK117Y ?
Regards!
Regards!
Zeljko said:I have an old stereo receiver which has two FETs in preamplifier stage, they are 2SK117 and probably they doesn't work. I bought new 2sk117, but what I wish to know; original FET was 2sk117 GR and I have new 2SK117Y. The different between those two FETs is in IDSS,
Regards!
1. mebbe it will work ok
2. mebbe it will sound sound distorted
3. mebbe it will go puf
just try them
I would also recommend you to use GR or BL. Using Y will probably place the FETs in positive-bias (if e.g. driven by a CCS) -- bad idea.
But it will make life much easier if you have the schematics.
Patrick
Patrick
Patrick
OK, here it is...
Regards!
Are you sure the old ones are bad? They aren't known for failure...
One part on your schematic IS known for high-failure...D1 and D2, the VD1212 diodes. They can be replaced with a simple series pair of 1N4148 diodes. If you're having problems with that part of the preamp, get rid of the VD1212 diodes first. Every time I find them, I pull them out.
...looks like a Sansui something-or-other...
EchoWars said:Are you sure the old ones are bad? They aren't known for failure...
I am thinking that someone has connected DVD Player or CD player on that Phono input…
I checked those two diodes by digital multimeter, and they are good.Originally posted by EchoWars
Yes, it is Sansui receiver 🙂Originally posted by EchoWars
...looks like a Sansui something-or-other...![]()
What's new on AK 😉 ?
Regards!
Well, they nearly always check out fine with the tiny current that a meter puts through them.Zeljko said:I checked those two diodes by digital multimeter, and they are good.
I'm not sure that feeding the phono input with a CD player would kill it. I don't think it would have sounded very good, but it really should not blow up the phono stage.
Is the phono dead? Or just sound bad?
EchoWars said:Well, they nearly always check out fine with the tiny current that a meter puts through them.
On what better way I can check this diode?
EchoWars said:I'm not sure that feeding the phono input with a CD player would kill it. I don't think it would have sounded very good, but it really should not blow up the phono stage.
I got this receiver in very bad condition, and both channels on this phono stage are dead. I bought in local store some 2SK117 but not BR or GR, just only Y (as I written before different is only in IDSS). So, what will be if I replace that original with this Y FETs? Can it work for a long time, if it will work?
Regards!
regards!
just replace them
I told you that already.......
Zen Mod said it...just replace them. Not worth wasting time on them.
As far as the phono not workng, sounds to me like you're replacing transistors without knowing why. Attack this problem with a little bit of logic and some old-fashioned troubleshooting methods. Measure some voltages and see what the transistors are doing.
Does it means, every time when I found VD1212 diodes, I need to replace them 😕 ??Zen Mod said:
just replace them
Regards!
Echo, I checked transistors and those diodes, and it seems to me they are good. My logic told me that maybe it is problem with those FETs. So because they aren't expensive, I bought some of them to replace, but I am wondering do they work because of lower IDSS. But OK, I will replace them and see what will happen.
Regards!
Regards!
depends;
but- if you are in sort of repair beeezneeeesss , you'll find some techniques as fastest and less troublesome .
replacing crummy old parts, (elcos ,for instance) then became just routine ;
remember- time involved in any repair is often of much bigger value than parts price
Zen Mod said:
depends;
I am not really repair service, I am doing restoring old Sansui receivers, amplifiers and tuners. Because of that I have so much originals NOS parts for Sansui devices and many original Service Manual.
When some part is dead, first I wish to buy a new original (because of that I am asking you about those 2SK117, I wish to know can I replace BL or GR with Y in future too, if I need to replace some of them) I know about elcos look my web sites:
- Restoring G7000
- Restoring G5000
Regards!
I was just about going to point you to the most obvious: fuses and voltage rails.
Since you seem to know your stuff, discard this post unless you really didn't check them. 🙂
/Hugo
/Hugo
Thank you Hugo, but what is strange, all voltage test points show me correct voltage (OK with small difference in value from value in SM, but this is normal), and this phono stage doesn't work, I have characteristic noise from it but not sound 😕Netlist said:I was just about going to point you to the most obvious: fuses and voltage rails.
/Hugo
Now I dont have some free time to replace those 2SK117, but I will tomorrow, and I will post here the results.
Regards!
- Restoring G7000
- Restoring G5000
Regards!
OK- good to know....... 😉
anyway- you must find a way to calc working parameters of 2sk117 from schematics or actual circuit; then you'll know can you put Y part in it,thinking about Iq and max input swing on jfet's gate.
you need 2sk117 pdf data , and that will tell you everything you need to know .
In case that you don't know how to calc this,it's handy- for future , to learn.
there are few ways to find out are these jfets in your actual circuit working or not; just measure current through R9 and R11
as I see it- you must have 2mA through each jfet ; well worth at least trying to put Ys in place and try it. they will not be burned; worse thing can happen is distortion . but- in that case you'll at least know are these original jfets defective or not.
just power your iron and brain, don't waste time on typing
OK, here it is datasheet 😀
Zen Mod said:there are few ways to find out are these jfets in your actual circuit working or not; just measure current through R9 and R11
I am not so good with testing FET transistors, so this advice is so good for me. If I am not sure what to do, I rather ask before doing something!! Thank you!
Originally posted by Zen Mod just power your iron and brain, don't waste time on typing [/B]
But today is Sunday, its nonworking day 🙂 !
Regards!
- Question about FET 2SK117 in old stereo receiver
