question about a possibly blown speaker
One of my speakers produces no sound, but when i put the slightest amount of pressure on the cone it plays clearly. I was just curious if anyone knew it this means the speakers is blown and if it is fixable or do I need to replace the speaker. thanks
it could be a bad solder connection or loose wire at the speakers terminal that could be re-soldered or it could be a blown voice coil that is loose inside the speaker and makes a connection when you push it in, if this is the case it is usually not fixable.:hot: Good luck.
