I would like to ask a question about the crossover frequency.
For example, if i have two loudspeakers, one tweeter (
Goldwood GT-510/S 1" Shielded Soft Dome Tweeter | Parts-Express.com ) Specifications: *Power handling: 50 watts RMS/100 watts max *VCdia: 1" *Impedance: 8 ohms *Fs: 1300 Hz * Frequency response: 3,000 - 20,000 Hz *SPL: 90 dB 1W/1m
and one woofer Specifications: *Power handling: 80 watts RMS/170 watts max *VCdia: 1" *Le: .40 mH *Impedance: 8 ohms *Re: 7.0 ohms *Frequency range: 35-5,000 Hz* *Fs: 55 Hz * SPL: 86 dB 1W/1m *Vas: .50 cu. ft. * Qms: 3.60 *Qes: 1.09 * Qts: .83 *Xmax: 2.5 mm
How can i determine the crossover frequency?
