Quest L600a peak light stuck
Hey guys, I have a Quest Qmotion L600a system and I was curious if anyone knows this system?
When I run music into it the sub works and the right satellite works but the left side is a bit quieter
and the limit light is constant red even when you have no signal running to it and no speaker attached.
It would be a massive help to narrow it down to either the output board or the pre amp board.
I'm thinking the pre amp board???
Cheers
Cheers
Hi Hayden, I have owned a L600A sub-satellite system for many years and the signal/limit circuits are known to be odd. My LED indicators visually respond different to each other but level wise the end result is identical. I raised it with the importer and they were pretty meh about it as these were pretty much regarded as prototypes for the newer QMotion series. If you’re wanting to sell your sub/sats and move them on, let me know, I’d love a second sub to make a pair and could probably repair the limiter issue… I’ve even changed the wheels and power switch on mine to keep it going
