Quasimodo results (ONLY)
Antek AN-0112
Cx = 0.01uF
Cs = 0.15uF
CT Configuration - 24 ohms
Dual Secondary Configuration = 34 ohms
Antek AN-0115
Cx = 0.01uF
Cs = 0.15uF
CT Configuration - 30 ohms
Dual Secondary Configuration = 40 ohms
Note - I don't include additional significant digits / fractions of ohms. I get it close enough and err on the higher side for resistance.
Signal Transformer DPC-24-450 // PC mount transformer // 10VA // dual primary // dual secondary: 2 x 12VAC
CONFIGURATION 1: SEPARATE SECONDARIES (12VAC to DiodeBridge1 , 12VAC to DiodeBridge2)
OPTIMIZED SNUBBER FOR EACH SECONDARY
Cx = 10 nF
Cs = 150 nF
Rs = 120 ohms
CONFIGURATION 2: SECONDARIES CONNECTED IN SERIES (24VAC to OnlyDiodeBridge)
OPTIMIZED SNUBBER TO USE ACROSS THE 24VAC SERIES CONNECTION
Cx = 10 nF
Cs = 150 nF
Rs = 215 ohms
CONFIGURATION 3: SECONDARIES CONNECTED IN SERIES (24VAC) AND
WEIRD/UNUSUAL CAPACITOR VALUES. WHY? FOR FUN OF COURSE.
Cx = 680 pF (0.68 nF)
Cs = 1.5 uF (1500 nF)
Rs = 740 ohms
AnTek AS-0518
2X18V 50VA
Cx = .01uF
Cs = .15uF
Rs = 44.2Ω
Reactions: bhjazz
