Actually I have (24) 2V batteries, but your point is well made, it would be easy to tap the mid point. One issue: the Neg terminal of the first battery is connected to Earth ground via a 4' copper rod driven into the ground. This rod is also the Earth ground for the AC side of the house. As long as I stick with "double insulated" - i.e. no third prong - equipment for the source, I guess I would be OK. Nothing in the entire HiFi system would need to be referred to Earth. At this point, it looks like my primary source will be a Raspberry Pi with an I2S DAC configured as a music server. The power supply for this is SMPS which is isolated from Earth (at least there is no third prong and I assume the output is isolated from the 'neutral' side of the input). Even if I build a linear supply, the transformer will isolate 'ground', correct? If NOTHING is referred to Earth ground, then taking power from 0V, 24V, 48V should be fine for -24, 0, +24. All I need is a couple of big caps (say 20,000uF) and I have a "power supply" suitable for my Aleph J, correct? I will use the Salas BiB boards from the same source to power the preamp and XO.But your 48V battery bank is made from (4) 12V batteries in series... You could make a virtual ground in-between the two center batteries and you're done. Ground is relative.
Does anyone see a problem with pulling a couple amps off the +24V side to power the Pi (using, for example, a LM338)? The battery bank is so huge, it will never notice the difference. Would the amp? Take it off before or after the big caps? (Probably before, I think) This is beginning to sound do-able. I can't wait to get back to Panama to do it.
