Last time I powered up my panels with the completed EHT, I got attention on a faint sparking sound, about 2 arc per a minute.
The source was the red circled spot, next to the edge of the transformer.
May this because of that I painted these 'rails' and there is no continuity between them and the transformator? I had no luck to see if the arc jumps between the two or only between the transformer's laminations.
Thank you for your help in advance
