QUAD 405 clone
Saw these accidentally, maybe another version of it, the tiny heatsink will be OK?
@ejp , thx for pointing these out. Good to know. I thought I read it somewhere, these “vertically“ mounted transistors version is a better one, I guess this is not the case. Still learning here. Want to experiencing Quad 405 or clones and try to find where to start.
The advertised wording for the eBay one contains several errors such as 'class A dynamic biasing', and you can just remove N1 and N2 in a real 405-2: no need to jumper anything. The one in your picture is a 405-1, given by the current limiting transistors Tr5-6, and doesn't appear even have D13 which is the most important modification of all.
The first attached schematic is what someone else created for the LJM Quad 405-2.
The second attached schematic is the Quad 405 MK2 schematic. (At least what I found online.)
Does that seem right? If so, it has D13 (as labeled in the Quad 405 MK2 schematic) but does not have the diode between the bases of TR9 and TR8 (of the Quad 405 MK2 schematic.)
It's fairly easy to add the diode, but you have to cut a track.
I didn't say anything about removing Tr5/6, and I can't see any reason to do so. You can improve the way they operate: find the Berndt Ludwig paper on the 405. It also tells you why D13 is important, and it is: it reduces THD by 2/3 at high frequencies.
