HI - I have a recently purchased Quad 33 pre which is feeding into my 303 power amp, of course. I notice that the balance control needs to be far over to the right in order for the sound to be central between my speakers. It sounds great, but I'm wondering if anyone can shed light on this control and what might be causing this?
Welcome to diyAudio 🙂
I believe one issue can be that the volume control can suffer poor tracking at low levels so you need to rule that out first. This is made worse with high output modern signal sources which mean the volume has to be kept low.
I'm guessing (maybe incorrectly) that you haven't a scope and signal generator as that is the sure fire way to prove conclusively what is happening.
Thanks, no I don't have such equipment and really wouldn't want to go there! I just bought my friend's 70s LP12 fitted with a Goldring cartridge and playing through recently acquired Monitor Audio floor-standing speakers, listening to Springsteen's Tunnel of Love album and it sounds just fantastic! So, maybe it doesn't matter where the balance slider is at? No issue with the volume knob that I can hear.
I do have a mutimeter.... if the pot is not centred, can it be adjusted? It would be nice to have this control working... I believe the mechanism is intact.
Mis tracking or channel matching of the volume control would show in the centre image shifting as you change the volume setting. Typically the more the pot is turned up and the more accurate the matching becomes.
Do the line inputs also need the balance control shifting to one end to centre the image, or is it just the phono input affected?
You don’t need to take it apart, not even the front panel, just remove the case. You can do it all from the top and side with a long screwdriver.
@ejp suggestion is a good one:
Put your meter on ohms and connect the black meter lead to ground (chassis) and measure in turn to each arrowed point (which is the negative end of the two capacitors). With the control centred you should see approximately 500 ohms to each arrowed point. The 1k pot could have a 20% tolerance but you are looking for approx equal readings to both points.
Check that the pot is electrically centered at the centre position of the slider.
In other words just measure from each side terminal of the pot to the centre terminal. Should be equal at slider centre.
Would that work? The end pins are essentially isolated at DC and have no knowledge of what the centre pin is doing.
I just found the mid-point resistance-wise (460 ohms) so that centre to left was the same as centre to right terminals, then tightened the two screws and now centre is centre and I'm very happy! (which I realise is what has been said above...)
- Analog Line Level
- Quad 33 Balance Control Issue
