I'm working on my old Quad 303. It deserves a little attention.
One problem is that awkward power connector - mine had a broken pin and soldered power leads. I've made a template for replacing it with an IEC connector. Worked really well.
Here are some pictures.
I've drawn up the panel, if anybody needs the file drop me a note.
Hi
303 is nice vintage amp. I have one.
Bulgin PX0429 3 Pin Male Socket, Quad 303, Racal 1772 | eBay
Quad303 Quad 303 pcb set for renovation/cloning V.4 | eBay
2x BULGIN 3 PIN MAINS CONNECTORS FOR QUAD 33, 303, FM3 | eBay
But of course it will be good ide to replace input connector too......
Best regards, Taj
Best regards, Taj
When I restore mine 303 I find some nice caps from epcos......with bolt on terminals.....
Those filter caps have had it😱 Better change them REALLY soon (like yesterday) as they are leaking electrolyte.
rob
rob
At the moment I'm on vacation but can check which caps I used.....but I buy everything from farnell......
Best regards, Taj
Best regards, Taj
I've bult several 303 clones but with some mods. The best was to use new epi 3055's and most of the HF roll-off capacitors could be halved. Performance improved from the standard 35 kHz with original capacitor values and RCA original transistors to over 70kHz, using ST 3055's (but I suspect ON semi would be similar) and (at least I thought so) sounded better for it.
John
John
I did a true esoteric renewal of 303, upgrading all except the original casing and transformer. Epcos, Elna, Wima, RIFA & SMica Caps, Bourns trim, Kiwame, Mills & Takman resistors, ON Semi 15030/31 + 15003/4, J507/510, Van Den Hul cs18/16 wiring... But, the new metric screws are not matching to the old ones!!!
Does anyone know where I can find new screws for 303 (4BA thread)?
Branko, Serbia
Branko, Serbia
- Quad 303 IEC power socket upgrade
