I am looking to build a 3 way using pro drivers, and was curious. My reading says a QTS of 0.5 should be used in a sealed enclosure. Is this correct?
This is the driver I was looking at:
Beyma Speakers - Beyma 12BR70 speaker - Beyma 12BR70 250 watt 12" woofer for all hi-fi and studio monitor bass speakers. Beyma 12BR70 and other Beyma 12" speakers here.
Sub bass is obviously not what I am going for, and hoping this driver can be used up to a higher level say 800hz or so, allowing it to be used with a SEOS waveguide in the future should its initial implementation not succeed.
Is this driver capable of being used in a ported enclosure, or is it a sealed only driver?
Both . I am not vouching for how good this is but here is a calculator you could play with. According to it 5 cubic feet is just about right. Speaker Box Enclosure Designer / Calculator
Thanks for the replies,
Will use Unibox to model it in a sealed alignment. I must admit am a bit new to Unibox and changing particular variables... this will be good experience.
I was a bit swayed by the low FS and reasonable price of this woofer. The idea of using it up high is also a plus... perhaps I should seek a different woofer that can be used ported and go lower? I don't want to get any larger really. 15 would be pushing it, and would have to have a fair deal of benefit over the 12 and not be a leap in price. Seems unreasonable.
Has anyone used the 12br70?
