I have an smps prototype using the schematic in http://wintermute.csbnet.se/~zilog/schemat.jpg
I observe the waveform below on ISNS_OUT, but its the same at ISNS, except the smooth downslope - http://wintermute.csbnet.se/~zilog/smps_currwaveform_synthesized.jpg
1 div is full on-time for one primary phase, 1 div is 20A current. Is it normal that when one primary stops conducting, the current in the other phase continues where the other one left off, but then again it all begins at zero? I would expect to see sawtooths that return to zero, or the same level atleast between each conduction interval.
I suspect this causes the smps to duty cycle-limit at 60% given high load.
EDIT: the smps uses Average Current Mode Control
