Push Pull driver newbie question
I'm only an student, and I have built a few push pull amps, all using BJT output devices with a single ended driver, I just want to learn how the push pull driver works and how to design an amp using this stage. i want it to drive a push pull output stage.
Thanks for everybody !!!
Nice to meet another student here!! Welcome to diyaudio.com!
What exactly do you want to know? I've put a schematic below of an amp I've just made. So which part you want us to tell you how it works?
best regards,
HB.
some info for Diogo:
R8 and R9 are there to limit the current through the diodes, they can also be replaced by a current source
the diodes are needed to avoid crossover diistortion, also other devices are common.
Q5 is the voltage amplifier stage (C3 reduces higher frequency oscillations), the gain is equal to R12/R13
Q3 and Q4 is a differential amplifier (R3 and R4 reduces little differences between Q3 and Q4). A differential amplifier only 'allow' different signals to go through. (i.e. if the same signal is applied to the base of Q4 and to the base of Q3 there won't go a signal to the base of Q5). When no signal applied, the diff. amp. is 'in balance' => the current through Q3 (I3) is equal to the current through Q4 (I4). I ~ (12V - 0.6V)/R5 = I3 + I4
I3 = I4 so I3 = I/2. Calculation of R7: R7 = 0.6V(Ube of Q5)/I3.
HB.
I think it is very interenting, By taking the signal from the emiter the output devices are "looking" at a low impedance input, isn't it great when we talk about mosfet output devices? Won't we get a better low frequency responce?
tiroth,
I've been thinking about the same thing, I think you can do it with the same diff. amp but I'm not sure.
to diogo: sorry I see now you were looking for the push pull driver and not the single driver (sorry, I've read your question too fast)
HB.
