Push Pull 45
I have a good number of 45s myself, been collecting them for years. I generally reserve my globe 45s for SE use, since it's so difficult to find a pair that will bias together, even with adjustable bias. I've not had an issue with microphonics with them though.
I friend of mine has a small company that makes the chassis for me and I can highly recommend them: LandfallSystems.com. I do the chassis design in AutoCad and send the .dwg file to Dave. He sends me a complete (flat pack) brushed and anodized chassis. They can do other finishes as well such as powder coating. I do the labeling layout on AutoCad as well and I have a local person with a 65 watt laser engraver to do the lettering/artwork for me.
Nice, thanks for the chassis info. Oddly enough, I found them years ago, but at one point, I couldn't remember them.
I started using AutoCAD back in the 80's... had a licensed copy for testing early PS/2 Systems with the 386 and 387 math coprocessor. Can't believe how many different stepping level 387s Intel sent, before I got one that actually worked correctly with AutoCAD. I'm still using the same code... running on a Model 95 with DOS, as that older version used DOS as a launching pad with the old PharLap DOS extender to kick the 386 into protect mode. I ended up building a custom menu and a large collection of electronic symbols to create all of my schematics with... and another to do the chassis layouts with. I would then use an IBM 6180 pen plotter for 1:1 templates and create the chassis work from metal stock or modified Dynaco parts.
Funny enough, I also have a old friend/colleague that has a CNC router table with the laser burner/engraver. Once I get a bit further on some other projects, I'll be looking to get some anodized work from Landfall Systems for some new designs. Thanks again!
Reactions: rkoonce
The person who does my laser work has issues with anodized aluminum, but she's got it figured out. She uses Ceracote (I think that's the spelling). It's in a spray can and looks like a tan paint when applied. Laser the images into the coating (two times I think) and then wash away whatever wasn't hit with the laser. The rest is black and very durable.
