Re: Re: Purpose of Bypass caps
I must be losing my touch. I find myself agreeing 100% with Nelson.... Except that I find nothing entertaining in Jerry Springer.
Jan Didden
Nelson Pass said:
I regard this as a religious argument thing. I think religions are good and useful, and arguments between religious beliefs are interesting, and like the Jerry Springer show, even entertaining, but the fact is that solid information is hard to come by.
The good news is that you can build up your average circuit without film bypassing and it will work fine. Then you can go about the process of trying different sorts of bypassing and see where it gets you. This is the DIY part, and while it is helpful to listen to opinions, they should just serve as a starting point for your own exploration.
I don't usually provide bypassing information in my projects, except perhaps as a passing thing, because I expect that those who are the least concerned about these issues will find their own solutions and don't need my help.
On the contrary, my opinion would be a hindrance....
pass/ - not out to hinder DIY, and still enjoying halo style sign-off
Jan Didden
JDeV said:Continued 3:
Although this all is based on industrial applications, I am sure the theory will aplly to Audio as well.
The figure in the lower right hand corner of the picture shows
what happens if you pick a value that creates an resonance when
put in parallel with the big cap's parasitic inductance.
When there's a tendency toward ringing, what are the listening
impressions likely to be? "Smeared" transients? An "edginess"?
I presume that a lack of ringing would lead to a more relaxed
sound.
Sadly I lack the requisite equipment at home to set up the
condition, measure it to verify it is ringing to a greater or lesser degree, then listen to find out. :-/
eL
I think it's more useful to listen first, measure later.
When I listen first, I'm more free of the influence of the measurements, which is a powerful thing.
Also, I much more enjoy being vindicated by instruments than vice versa.
pass/ - still keeps one eye on the meter.
Let me also point out that the method of bypassing can be a science alone. Linear had a document about that when they have measured a couple of circiuts.
http://www.linear.com/pub/document.html?pub_type=app&document=50
Hi, im looking for some reading material on this subject, but the link is now redundant. Could you point me in the right direction of the article on the linear site please?
Thanks very much
Charlie
Some more from Texas Instruments:
This 1 is specifically about Op-Amps.
Abstract from Document: SLOA089
That link alone provides great points to follow. Religious cap crusades aside 🙂
