Purifi 1ET400A Input buffer
I'm thinking about building some slim monoblocs with the Purifi 1ET400A.
When I look online for buffers, it seems that there are only buffers where the Hypex 1200A400 is to be used. However, to me it seems like overkill to use this when it is to be used as mono. In addition, it is a bit larger 🙁
Is it true that you cannot buy or build yourself a buffer where the smaller SMPS600N400 is to be used?
Can anyone help with some links if available?
