I've mailed with (one of) the maker(s), and they clarify this in the manual for people like me... 🙄
Meanwhile, I can really recommend using sox for riaa playback along with a decent prepre and a reasonable adc/dac. Using sox with command line linux keeps the diy spirit as well.
Rüdiger
I'd like to push things a little further and try to implement different playback filters (CCIR and others) in sox's biquad command. So far, without sox-ess, haha. 🙄
I've found A biquad calculator | EarLevel Engineering but could not find reasonable values.
Should something like a program or spreadsheet exist that can spill out filter values for that purpose, I'd appreciate a hint or link.
Rüdiger
I read about Pure Music in The Absolute Sound forums and downloaded the demo.
In my initial listening tests, I found PM (compared to iTunes) to be anemic ...
I remembered) that I had used the iTunes equalizer "Acoustic" preset on all of my stored music along with a gain adjustment set to 70% ...
I did the best I could to reproduce the quality of my iTunes preset, but never quite got it there.
As I mentioned to the PM tech, I thought that Pure Music was supposed to be a sizable improvement in sonics over iTunes and not an attempt to match it (which is what he and I were trying to do together) ...
I'm not a sound engineer and I don't have the time to study up on all of these aspects of playback in order to take the Pure Music playback beyond what iTunes is doing for me now.
To the best of my knowledge, Pure Music does not have, as one of its design objectives, the goal of "improving" any iTunes EQ presets, so a comparison based on how close one can come to doing so really says little or nothing about the value of the software. Most people who have suggested that the software is an improvement on iTunes have been talking about straightforward unequalized playback, ie, "pure" music rather than "changed for a particular purpose" music.
Pure Music 1.8a
Release Notes / Changes
1.8a
• Issue with 1.8 distribution corrected (incorrectly reported new version available after installation)
• Issue corrected involving saving crossover settings between launches
• Changed device ID search string from MPS- to Playback Designs so other devices with USB - DSD
1-bit streaming playback from that manufacturer would be identified and supported
1.8 June 1, 2011
• New menu options to disable all DSP options, or disable DSP options except upsampling and invert
• Direct playback of 1-bit DSD audio files, with optional sample rate selection (by using Limit DSD
to PCM Rate) for on-the-fly conversion to PCM
• Native streaming support of 1-bit DSD audio to the Playback Designs MPS3 DSD stream mode
• New Software Playthrough feature permits playing other computer audio sources (Internet radio,
movies, etc.) through Pure Music (useful for accessing plug-ins, dithered volume and crossover)
• New one-click feature to assist in configuring crossover filters and appropriate bus arrangement
• New metering menu options to set the range of the meter (100, 60, 30 dB)
• Add FLAC procedure now works on contents of entire folders or disk volume
• File conversion to Apple Lossless now works on contents of entire folders or disk volume
• Sample Rate conversion now works on contents of entire folders or disk volume
• Removed Info button from sidebar to reduce clutter. Info can be toggled from the Metering menu
(or pressing command - I)
• Now permits upsampling 88.2 kHz tracks to 96 kHz, for situations where the audio device doesn’t
support 88.2 kHz (e.g., pre-2010 Mac built-in optical output)
• Moved Invert button to immediately below the Monitor control to better reflect its function of
modifying the audio signal
• New option to dictate (if the Comment tag in iTunes for the track includes the string gaplessbreak)
where best to break up a gapless album if insufficient memory is present to load the entire album
• New option if the Comment tag in iTunes for the track includes the string monophonic to play such
tracks mixed to mono
• 33% more efficient memory usage with gapless albums
• Corrected issue that could cause a snippet of a previous song to play if playback was paused and a
song with a different sample rate is played
• Now observes setting of Repeat One in iTunes for selected track in any playlist
• Improved operation of NetSend connect on launch and disconnect options
• Eliminated side effect that occurred when Adding FLAC files, causing the last track added to start
playing
• Corrected issue with gapless playback involving album boundaries
• Corrected all known issues involving Gapless playback
• Corrected a problem causing more than one gapless album to load at once
• Corrected problem causing noises to be emitted during playback of gapless FLAC tracks
• Corrected issue that could cause certain mono tracks to only play in the left channel
• Corrected issue that could cause playback to pause unexpectedly
Pure Music 1.8a is online!
1.8a
1.8 June 1, 2011
playing
