This is not same amp as other thread. Ok i replaced 2 output transistors both ps fets with 3205's and 47ohm res. On gates also replaced all drivers just because i have like a hundred of them dont know if they were bad. The amp works perfect only problem is when i turn remote power off the power led stays on, but it disables amp like it should?
- General Interest
- Car Audio
- Punch 250a2 problem
