me thinks that they're olde americanino Lewyt xformers , which truly yours personally butchered from olde americanino WWII xmiter ..... on junkyard ......... where else ?
one xmitter - one xformer
3K6:18K
something like this - from machmat pagines :
3K6:18K
That is slaughter !
(for Jacco : Mon coeur pleure mais ma bouche-rit
Manu
Looks elegant but I prefer trotzdem the idea of Susy toobs output
Zen Mod said:hehe
lookie lookie
they make weaker drills lately ....... in Ostrich ..........
It looks like you also need a nice pair of flush cutters for those technicolor tie-wraps...🙂
But then how would he re-tension them after burn in?
Ostrich ....... not Serbia
Pinch with a nice pair of long-nosed pliers...?
Are you kidding?
Manu
Ps : I hope there is nothing wrong with this ...technicolor tie-wraps , because I ran out of valium today...
Nothing broken today...
Hehe.
But you sowed doubt in my mind about the method used to thermal coupling the Zistors.
Would Schrumpfschlauch/Heat-shrink tubing/Krimpkous (thats for frère Jacques) instead of tie-Wrap be a better solution?
Manu
Anxious
Hehe.
Manu
Anxious
Manu said:Nothing broken today...
Hehe.
Manu
Anxious
why not ?
same length/height as tie-wrap - leaving exposed as much you can of eeny weeny TO92
Hehe.
Manu
Anxious
No, it would not offer any tension once just around 45C, cause it turns soft at that temperature.
Zip ties or metal is the way to go.
Magura 🙂
Zen Mod said:hehe
lookie lookie
I have tried on many occasions to tap sinks and always ended up drilling right thru cos I screwed up(no pun) and using a nut and bolt.
Is there a dark held mason's secret to this..If so could some kind soul please explain the tricks. I have a pillar drill and a set of metric taps(only one for each size tap).
Ed
Ed
'll explain that masonery for ya - if ya tell me what's "pillar" drill
here ya go :
http://www.axminster.co.uk/pricing/...oduct-Axminster-HD16BC-Pillar-Drill-22285.htm
but mine is not as sexy as the one shown in the pic
Ed
vitalstates said:
here ya go :
Ed
what's point ?
in through hole you make or in bigger dia hole ,than you need ?
through hole is a must - in 90% of situations , and exact dia for tap is easy to find ;
trick is in steady , slow drilling , lubricating is a must ( WD40 is handy , even if I use some more esoteric stuff - and you don't wanna know that's in fact nothing else than goat fat).
tapping - again lubricating is must ;
half turn right , then half turn back ........
coffee is obligatory , too .......
and no hurry
sounds easy ?
Magura said:
... Zip ties or metal is the way to go....
Magura 🙂
Example ?
thx
Manu
Zen Mod said:
what's point ?
and no hurry
sounds easy ?
For tapping in soft material like Al, I now prefer to use Hand tapping tool as I ended having must less broken tap than with drilling machines. I found that, this way, it is so much easier to control.
Lubrification with common lamp-oil (cheap) but I am not a profi.
For drilling, the opposite. I prefer pillar drill (broken drill on ZenMods pic is the result of free hand drilling on kitchen table, smoking and drinking a beer at the same time)
- Pumpkin preamp - ordered by Steen , official making thread
