HBarske said:I somehow knew those boards have a severe problem - it's impossible to get those output caps mounted...![]()
not a problem - solder them in XLR cable jacks
Manu said:What is inside these caps? Beer?
that's certainly only way that Pumpie+AJ combo sounds better than HB's integrated ..........
If not ... you can drink the beer, anyway...
Dolly Parton pre?
Cook Book
ya boyz are completely nutz
anyway - slightly updated Cook Book is uploaded ; few additional notes added .......
Click here for COOK BOOK
Papa's toy will be gone by next week
- some diy progress is urgently needed...
Not sure if those beer cans will make it into
, but I'll give them a try.
HBarske said:Papa's toy will be gone by next week- some diy progress is urgently needed...
Not sure if those beer cans will make it into, but I'll give them a try.
did you found enough material for translation (for our friends at Analog ) in last
regarding previous pic:
why don't you just tell that some thieves tooked that crummy amp from ya ...... ?
and - jensens will do , but - if you have some older Siemens of Rifa uglies, don't hesitate ............ Pumpie is made with old tech in mind 😉
Absolutely, thanks again. Will take some more days though, lots of work ATM.did you found enough material for translation (for our friends at Analog ) in last Cook Book ?
Possibly that would make it more complicated to get the next PL beauty for a review 🙄why don't you just tell that some thieves tooked that crummy amp from ya ...... ?
Regarding 😛umpkin: capacitors: Enough cans to play around, including russian PIOs. We'll see...
HBarske said:
.............Enough cans to play around, including russian PIOs. We'll see...
most old drek you can see at Jogis Roehren..... - old Rifa,Siemens , ROE,Wima .............. PIO and Poly ...... are absolutely delightfull for modern electronic ; dunno what's catch - maybe fact that you can find real foil in them , not metalized dielectric.......
anyway - I like those old "Post" caps 😉
Hey ZM,
Maybe you could mention the pages that have updates in the latest
Cookbook- you know, then we could save all those trees and not reprint he whole thing ..
Variac said:Hey ZM,
yes Bwana .........
just one page added .......... AS LAST ONE
there it is (I mean text ) :
ADDITIONAL NOTES :
HEATSINKS :
Fischer
SK81-50 SA
SK75-50 OR
Austerlitz
KS100.3-50
KS32.1-50E
CONNECTION :
You can connect Pumpkin inputs and outputs in all combinations you can imagine ;
My advice can be – use balanced pot(s) for inputs (either one 4-deck , or two independent stereo pots) in any value you choose – from 5K to 50K , log off course .
Then use XLR chassis connectors for all inputs and outputs .
That’s certainly most convenient if you choose balanced input – balanced output configuration .
If you choose to use unbalanced either input or output (or both unbalanced) , again use XLR cable jack even for unbalanced ,and just tie ( solder) pins 1&3 inside that cable jack .
So – these combinations are possible :
- bal in : bal out
- unbal in : bal out
- unbal in : unbal out
- bal in : unbal out
In every “unbal” case – you must tie 1&3 pins in XLR ;
It’s also possible special situation – where you use bal out and unbal out in same time, but (naturally) WITHOUT tying 1&3 pins of output XLR (just because tying those pins you are just killing balanced out entirely) , where you as “unbal” out are using in fact just half of balanced signal ................... where HOT is from pin 2 (+ output) and gnd is from gnd , what else 😉 ; That’s useful for biamping purpose , where one power amp is balanced and other is not .......... and 6db difference between balanced and unbalanced is something that suits your needs .........
who will print entire drek , without looking what's in it?
I did look what's in it and discovered that it was very time consuming to look through each page for a single changed word or number or such!
I guess it was especially hard because there weren't any changes to find- except the last page!
I DO appreciate the notes though- they are about stuf I had asked about in part 🙂
I just got some huge Rifa's off ebay so I can also have the Big Bulky Cap look!😎
Variac said:some huge Rifa's
Jules have to put them on stands cause the lead spacing is off by 40 Mils.
HBarske said:
.... PL beauty for a review 🙄
Hi Holger,
Deine Review über d. INT150 würde ich aber sehr gerne lesen. Wo wird sie denn erscheinen?
Manu
Manu said:
Hi Holger,
Manu
HBarske said:Next issue of "LP" magazine.
Manu said:THX
Zen Mod said:
ADDITIONAL NOTES :
iZMogood :
Thank you for ansering questions I just wanted to ask 🙂
I appreciate your Cookbook very much.
And particularly the how-it-works-section is a very good place to learn .... at least for newby like me.
manu
- Pumpkin preamp - ordered by Steen , official making thread
