Pumpkin preamp - ordered by Steen , official making thread
Still talking about gain & feedback -
I guess the value of R6/R3 determines the amount of negative feedback to determine the gain.
Other than voltage swing / gain - if there any other effect of changing the feedback/gain on the audio signal? Bandwidth wise or distortion wise.
I've read previously that more negative feedback (lower gain) will reduce distortion but will also limit the bandwidth. I assume that with the value of gain chosen for pumpie 4.7-15, there shouldn't be an issue with bandwidth?
her shann
Manu said:
What should I say, Clean job Steen
Please Bwana , you know I always need some explanations, even if its obvious for the most.
Manu
Greedy to learn
Take a close look at ZM's picture. The -IN is simply shorted to ground at the header, (connecting the particular input) through a small piece of tinned CU wire, so when the relay of that particular input is selected, it will automatically short -IN to GND. Pretty bright idea, or what...
Zen Mod said:
that reminds me .......
steen - you tried chip susy preamp ....... ? ( if I remember that well)
what's difference comparing it to Pumpie ........ neglecting output swing issue ..
The twisted X-driver, as they call it, actually does perform wonders. I like it a lot, indeed. If its for sentimental reasons I dont know, but I find the Pumpkin more musical and a tad less "clinical" to listen to. Noisewise the Twisted X driver is the winner. I never experienced anything like it. With the volume at full throttle (no signal ofcourse) there isn't even the least bit of hiss😱 The Pumpkin is absolutelly good in that respect also, but there is a slight trace of hiss at full output. Not that it matters for all practical purposes at all. That slight hiss, can never be heard with a signal on😀
Having been listening to the Pumpkin for a while now, I must confess that it is my preamp of choice! It simply does have it all: Sweet silky topend details, very nice and warm midrange (voices) and a very firm bottomend! Now thats all pretty much heard before, but the Pumpkin has the very important "Foot-tapping"-effect like a X-BosoZ😱 I never thought that I would find that combination in one preamp! But here it is. I find it hard to keep my feet still, when using the Pumpkin😎
Thanks a lot, Choky😉
yup , but not exactly ;
ratio of both sides R5/R1 AND R6/R3 is determining gain
nope
hershann said:
I've read previously that more negative feedback (lower gain) will reduce distortion but will also limit the bandwidth. ....
it will reduce distortion, but broaden bandwidth ; contrary to what you read :clown:
hershann said:
... I assume that with the value of gain chosen for pumpie 4.7-15, there shouldn't be an issue with bandwidth?
her shann
it will be bandwidth changes , but your ears certainly will not hear difference ......
:devily:
Steen, Thanks, but I have to think a little bit about...
(You mean that said input is then always RCA?, definitively non-XLR, nevermore...)
What you says about Pumpkin is absolutely what I expect from this Serb-Jewel.
Peanuts butter and cevapi.
I can't wait to finish mine...
there is no need to thank me ........ and to make me blush ( even if that is pretty impossible :rofl: ) ;
I was interested in exact difference (sound etc. ) between these two sides of same coin...... hehe - even if mine is pretty gray comparing it to certain complexity of chips ...... :clown: ...... thinking about difference in efforts to make one or another and final results ....
in any case - if these chippy dreks are made by Papa's pattie pattie , they can't be bad ..... so easily
:rofl:
btw - I can't find exact schmtc of twisted X without too much trouble ..... (seems that today search func and me aren't in good relation 😕 )
have you linkie to exact post ............
hehe - I can bother ya - seems that your shoulder is certainly better - more than one post in a week 😉
EDIT
I found it .......... 4 eyed ZM ...... 😉
http://www.diyaudio.com/forums/showthread.php?postid=921115#post921115
Chocky says :
- was interested in exact difference (sound etc. )
- .. I find the Pumpkin more musical and a tad less "clinical" to listen to. ... I must confess that it is my preamp of choice! It simply does have it all: Sweet silky topend details, very nice and warm midrange (voices) and a very firm bottomend!
Now thats all pretty much heard before, but the Pumpkin has the very important "Foot-tapping"-effect like a X-BosoZ I never thought that I would find that combination in one preamp! But here it is. I find it hard to keep my feet still, when using the Pumpkin ... Steen says
Nice review nicht wahr?
Manu
Quoting is creavivity
:rofl:
Yep, shoulder is pretty good, so I am posting again using too much time on PC, so shoulder is gonna be bad again:dead:
There is all reason to thank you!! You have been giving more to the DIYaudio community than anyone else (except Mr P. ofcourse) Babbelfish & Pumpkin, together with a never ending will to help out!! DIYaudio would be a poor place, without you😎
Here is the TXD manual made by the two great pears:
http://www.twistedpearaudio.com/docs/txd/txd-doc.pdf
For a chip, I can assure that it sounds just great! I was pretty surprised to find out!
Oh, and here is a piccy of the mess, look at them small TXD boards:
steenoe said:
Yep, shoulder is pretty good, so I am posting again using too much time on PC, so shoulder is gonna be bad again:dead:***********************************************
after that post of yours , only I can is to crawl under greatest rock I can find , for at least few dayzzzzzzzzzzzzzzzzz 🙄
just one thing before that (crawling ) - what's easiest way to find few these chipsies for playin' purposes ........ ?
(I'll not mention how that thingie will work even with plain simple shunt reg ........ :rofl: )
Its not even difficult, when you look at it the right way🙂 Imagine this scenario: You have balanced inputs and single ended inputs! 2 inputs are reserved for balanced signals so they are left untouched!! Input #1and#2 are reserved for that! Now #3 to #6 are supposed to be single ended inputs (SE) So those will need to have the -IN grounded! Follow me so far?? Well, in case of the Darwin running balanced, there is 3 connections for each channel: + - and GND. What I did was to connect (short) the -IN of input 3-6 to GND right at the Darwins input selection!! You could do the excact same thing with a normal input selector with 4 decks....
Steen.
No reason to hide under rock...😀 I am sure a lot of folks around here says the same😉
There is no easy way of finding those chips, I guess... National Semi more ore less shut down on samples! (Chipamp anyone??)
I have some that I bought from Digikey. I would be more than happy to send you a few of them🙂 Wont cost you a dime😉 They are sort of SMD, so be warned😀
ZM - from under the rock
Manu said:
Manu
you must tick "quote" field and try later to not delete these bracketed parts :
[ QUOTE ] [ i ] Originally posted by Manu [ / i ] [ B ] in front , and
[ / B ] [ / QUOTE ] on end of post you are quoting
:rofl:
being a professor is somewhat ......... something 😉
I know that - my better half was/is professor , beside other things :clown:
that will be more than welcome - as soon you receive substitution for magically vanished pcb from Rovsing's drawer ........ :clown:
just curious - how much they costed at digikey?
are they still available ?
Re: ZM - from under the rock
:rofl:
Manu is a professor🙂 If you (Manu) have trouble with something, send it to me and I will fix it😀 I am not a professor, I am just plain stubborn😀
He-he, Rovsing never found out what happened😀 😀 The poor chap is way too slow😀 😀 Besides that, he fart too much.
They cost in the neighbourhood of 4-5 USD as far as I recall... I will check it out.
