Thinking of putting together the Opus balanced DAC (as described in the Digital section of the forum) to feed the pumpkin.
Can the Pumpkin accept a common mode DC of 2.5V? I am wondering if I can omit the DC coupling caps at the DAC output to improve its sound.
The pumpkin has output caps - thus will block any DC from going to the power amp - but will the DC itself damage the preamp?
her shann
her shann
Zen Mod said:but I'll not make any fuss if someone publish his own variant .........[/B]
I dub ye the .................. The Squash, with his trusty side-kick power supply The Gourd!
hershann said:Thinking of putting together the Opus balanced DAC (as described in the Digital section of the forum) to feed the pumpkin.
her shann
nope ; you can't do that - from two reasons - you have attenuator ( pot ) on input which is based on ground ; even in case that you use shunt attenuator (between two inputs , without connection to gnd) , gates are still leaned/based on gnd
after universal Headphone preamp , you now need voltage convertor .......
you can't have anything .
put xformer on output of your DAC
We are GREEDY boys - 1 Pumpkin to rule (do) them all!
I'll just use the coupling caps on the output of the DAC then before feeding the Pumpkin.
her shann
Cookbook says EI transformer is preferred - I supposed due to better noise characteristics and ability to withstand DC etc.
For my Pumpkin the transformer is going to be mounted near the front panel and the audio circuit right at the back (the pot probably actuated via an extension rod).
So should I go for the old EI transformer 250VA, 42VCT x2 (pic 1) or the toroidal transformer 600VA 90VCT (pic 2). They are similar in price - with the EI at $20 and toroidal at $29.5.
BTW how easy is it to shield the EI's stray magnetic field?
her shann
her shann
hershann said:Cookbook says EI transformer is preferred - I supposed due to better noise characteristics and ability to withstand DC etc.
her shann
use that EI and place it in separate box ; 600VA donut is really overkill ....... even for Pumpkin
both transformers you show are probably too large ( physically and inducing hum wise) to be in same box with active electronic
last last watt F4
you can probably drive it balanced ........ with omitting few last resistors in Pumpie , you can also omit input resistors and big input caps on this last last watt F4 .......
or I'm missing something ....... as usual .........
last last F4
Interesting drawing, but I think you'll still need something for balanced to single ended conversion, because the input you have shown on your last F4 must have identical phased inputs, only with 8V dc difference...
I bet pumpkin will kill those tl431 very fast! 😀
Re: last last F4
dunno ......... I'm still fuzzy - flue ....... dumb ( that last like always 😉 )
I'll think more maybe tomorrow .........
cviller said:Interesting drawing, but I think you'll still need something for balanced to single ended conversion, because the input you have shown on your last F4 must have identical phased inputs, only with 8V dc difference...
My Shunty trannie pickings.
Single 44Vac secondary, means 2 trannies per channel, 4 total.
Split-bobbin type, primary winding in the bottom section and the secondary on top, metal shielding.
NOS Cheapo. (of course)
That's a lot of wires! Too complicated, no?
Re: last last watt F4
When you are out of flue and find yourself fine, I hope you will
look back into the last last circuit . . .
Papa feeds F4 with the one phase input to the all FETs 🙂
Zen Mod said:this last last watt F4 .......
mpmarino said:a lot of wires
4 times 4 is 16 wires.
2 transformers with 2*115Vac primaries and dual secondaries count up to....16 wires.
These are so small that they'll fit in a 3 1/2 " high case.
(burp, same height my Aleph-J cases will have)
Ya know,
I had a hard time deciding whether or not to put the trafo in the pre case. In the end I decided to chicken out and keep it outside. I've been having cr@p luck with noise lately - I think it's the 106dB horns' fault.
That is, when I can get back to work on this stuff - I had to put the pumpy on a high shelf
edit: Aleph J? is that anything like the Babelfish?
mpmarino said:.......
edit: Aleph J? is that anything like the Babelfish?![]()
dunno ............. will it drive F4 ?
- Pumpkin preamp - ordered by Steen , official making thread
