PTFE covered wire
The Highlights I see here are:
Yes buy silver plated Teflon wire from Apexjr.com, Steve Has good prices.
Yes plenum rated conductors do have Teflon insulation; the conductors typically are not silver plated. (best new material price option)
Yes the Ideal brand of automatic wire strippers work well.
DT
They have Teflon FEP, which lacks the main benefit of PTFE (high temp melting point). It will behave much the same as PVC and melt when you try to solder it.
EDIT: the melting point is higher than that of PVC, but still in iron-melting range.
PVC: 160C
FEP: 260C
PTFE: 327C
