PSUD2 Transformer Source Resistance
Tube rectifiers often specify the minimum resistance required in series with each rectifier to limit peak current. For a full-wave supply, is the PSUD source resistance for the whole secondary winding or, as with the voltage, one half of the winding?
I have used PSUD2 with Ubuntu for a while now, installed with "PlayOnLinux" . A problem created by Ubuntu imposing the snap version of Firefox is that the PSUD help files are not available from within the program.
PSDU support is now at https://groups.io/g/duncanampspsud
Duncan often responds within a few days.
The Help files are simple HTML. I had thought they were called from the Web (wrong); they are actually at
C:\Program Files (x86)\PSU Designer II\help
or under where ever your U-Snap puts PSUD files.
If SnapFireFox can't reach into a program folder, I'd call that "broken". I see others are saying the same. Perhaps if explained, Duncan can post a copy of the Help folder on the web where FF can read it.
FWIW, I don't see an explanation of this issue.
