PSU using TDA2040 ?
Hello All. :wave:
I found the following cicuit which I would like to use.
Could a power amp such as TDA2040 [ or 2030/2050 ] be used?
Or can anyone suggest an alternative opamp?
thanks.
Andy
steinchen said:
more than 20V across the regulators will produce a huge amount of heat, I'd rather pick a transformer with 18V secondaries, 3V across the regs is sufficient
how many amps does your TDA2040 amp draw ?
Hi.
To avoid confusion...
I intend to use the psu to provide +-12v at about 0.25 - 0.5a max and in single end mode +5v at 0.35A.
I have a stack of the TDA2040 chips and as they basically are a form of op-amp, could they be used in place of the power opamp in the diagram?
I have been told that this type of psu gives low noise - true?
Transformer voltages, preregulators will be adjusted accordingly.
Andy
Which PSU should I buy
I recently blew my Vox Pathfinder 15r transformer - I am using the tda2040 - and from what I am reading I should use a 12-0-12 40Va, to get +/- 17v - the problem is I have very little idea what that means, and I would like to buy the right (not to expensive) PSU for the amp. Anyone have a link for me in the UK - either on ebay.co.uk (like this one 48Va:
http://www.ebay.co.uk/itm/2A-Second...al_Components_Supplies_ET&hash=item3a614d8910
or is one of these the right one?:
Your Search Results | Farnell United Kingdom | Results
Thank you in advance for any help, I realize I should have left it to a professional - it's just that I got the amp for 40GBP, and the repair would ammount to more...
Best regards to all,
JJ
Oh this is my first post so Hi everyone!
