Testing the PSU
the psu coffin
It will deliver 90W per channel both channels driven with 8 Ohms.
Only after 2 minutes the heat sensor trips. Still testing, will keep you updated.
the psu coffin
The amp. sounds very nice. Not much different from my other setups(5). Only difference is the 5532 input opamp. This 1 does not sound as sharp/detailed as an 8620. Details are ok but the 8620 just gives an edge on soundstage. PSU is no problem at all.
Only thing is it will thermally trip if you test it too long with a continious full (sine)output signal. In normal playing conditions it will be ok.
