Hey jaymanaa, good luck with the searching! Sorry I can't help you with the case isolation issue. I sometimes ask questions which noone seems able to answer.
Anyway, one things for sure, any 370VAC cap will handle 520VDC. When I first posted to this thread, I looked up specs for some motor caps. It seems some can handle well over twice the AC rating (but for short bursts). I feel the way to be sure would be to read the specs for your actual brand.
Cheers
Cheers
Thanks indm, you have been a great help throughout this first stage of my first amp. I hope that someday I will be able to help someone getting started in DIY tubes. I have a good source for motor runs through a supplier I use at work. I will see if they can supply some more specific data. If so I will post it here. Thanks Again, Jay😎
Well I did some experimenting with a 500v meggar. I tried Mallory, GE, Mars, and Eccol motor run caps rated at 370 and 440v. Measuring from either terminal to case @ 500v the ohms readings on all was infinity (no leakage to case). This would indicate to me that direct chassis mounting would not pose a problem. I think I will disect one just for curiosity's sake. None have any markings indicating neg. or pos. so I assume they are not polarity sensitive.
I think I have read that the case of electrolytics should be assumed to be near negative in event of failure. Not sure who's site I saw that on.
But here is a quote from United Chemical
"Insulation From The Aluminum Can
The aluminum can is not insulated from the cathode, and when the internal element needs to be electrically insulated from the can, capacitors specially designed for these insulation requirements should be used. Also, the dummy terminal is not insulated from the cathode and must not be connected electrically to the anode or cathode. "
Hope this helps.
Hope this helps.
Definitely true for electrolytics, not relevant for motor runs which are non polar film caps designed for ac line operation. The case is well isolated from both capacitor terminals, however it is not a bad idea to ground the case for safety in the event of an internal insulation breakdown.
Picked up some motor runs today from one of my suppliers at work. I got the good ol'boy price of 6 bucks each. Anybody know what some of the labeling means. It says SH Capacitor Protected 10000AFC. I'm wandering about the abbreviations SH and AFC?😕 Thanks, Jay
Bumped this thread as it was the closest I could find to the subject.
New cap from Illinois Capacitor:
http://download.siliconexpert.com/pdfs/2012/4/9/2/5/26/679/ic_/manual/mpts_series.pdf
ESR = 0.0005 MAX
How many zeros before it does not matter?
ESR = 0.0005 MAX
the 440VAC have a 800VDC rating
come to think of it, ac rms voltage has an absolute value of about x3(peak to peak) so that in absolute sense 440volts ac is 1320 volts dc, therefore i tend to agree that an 800volt dc rating for this cap is just about right......
- Tubes / Valves
- PSU capacitors/electrolytics
