Psone Projector for sale. Sheffield
This is a psone projector made by me, and am willing to sell it for a good offer.
it has built in speakers,
250 watt light bulb. of which around 15 out off 6000 hours have been used.
3 phono conections, yellow, red, white.
picture will be uploaded if i find out how.
or post me email address for photos.
collection from sheffield, upperthorpe
if no reply it will go on ebay
i am using a HQI metal halide with conector on both side
http://www.facebook.com/photo.php?pid=49061&id=513498777
and this is what it looked like
http://cgi.ebay.co.uk/400-watt-HQI-...ryZ58145QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
do not.,,use a halogen, a 50 wat halogen is really hot, anything more is suiside
also when making the light engine, try to make the hole in which the ligh goes through to the LCD as small as possible, as it keeps the heat away and is exhausted from the rear
do what i did, i got a tempered glass and after that i placed MDF (wood) with a a hole to allow light throgh. the LCD remian cool.
the hole has to be big enogh so the f-lenses can magnify it.
also try to keep the Fres lens not too close to the lcd as they also heat the lcd up hot.
for best cooling place an air vent ABOVE the LCD but slightly infront of it
this is where cool air enters and cools the lcd. (even tho it dont get hot. just to be safe
http://www.facebook.com/photo.php?pid=49062&id=513498777)
then to allow the cool air to enter the light box area, do this make a gap 1cm high on the bottom of the tempered glass and MDF. (this gap can also be used to allow the wires to go pass.
because the cool air enters at the bottom, the warm air rises and the cool air replaces it and cools the light box. have the fan 10-15 cm behind the lamp on the back of the Projector.
this air flow is so good
messing around
built casing today and used for the front lens a disco moon projector lens. bunged in a fresnel about an inch in front of
the front lens put in a piece of plyboard with piece cut out
for lcd screen.
then i put in a piece of clear plastic instead of the lcd screen just to test it. drew a picture on it with a marker and it projected the image not to bad.
but i like the way you have done it a lot better
confession
because ciderman replyed to my posts, he kinda got back into the tweak mode of the projector buliding,
so i tweaked it and ended up removing the speakers from it to reduce the weight.
i cant be asked to post it tho.
its been a year with this projector and to be honest i prefer a better one as this is my first, i want to try a lilliput one day but i hate the screen door efects.
ciderman........., u could get away by using a 12volt hallogen 50watt bulb with a ballast. this would be great for light power but the heat is an issue. these are found in slide projectors.
these are best as the light is not yellow.
fffffffed
hi kingmully back once again like the renagaide master.
just learning as i said on my last post to you about the lighting side of things. soz if i have not posted for a bit but i have been buzy building the casing and faffing around with focusing and stuff
have just found out that my ps1 screens are wild something or other
and woz reading on the web tonight that they are not to good has anybody any ps1 screens original ps1 for sale or another option is the gamecube has anybody any info on the gamecube
screen
ps. how much were you asking for your projector i dont want to buy it i am just interested.
have you any pics of your projector playing anything apart from animation just to see the quality. not that i have anything against animation i love all the disney etc. but would like to see something like fast & furious or something or noffin
