PSD_Lite Beta 2 Update
Joined 2004
There is an updated version of the PSD_Lite (Passive Speaker Designer - Lite) program at the following link: http://www.audiodevelopers.com/Software/PSD_Lite.zip
This version addresses several suggestions that were made for the previous build and it has a lot of fixes. Most important changes are:
--Added a series filter before the crossover
--Redesigned the interface so the Crossover Module fits on a standard laptop display
--Improved error handling for the textboxes (error-checking now done on the "mouseleave" event)
This is still "Beta 2": the Beta 3 version of PSD_Lite will be released in the next few months, and it will include the Baffle/Diffraction Module. The Baffle/Diffraction Module also includes a box designer tool that helps in dimensioning the box, computing z-offsets for the drivers and calculates the interior volume.
Temporary installation quirk: If you installed the previous version, the installer will create a version titled "PSD-Lite-1". If you already have a "PSD-Lite-1" the installer will notify you that there is already an installation in the location specified and you will need to uninstall it first using Windows Control Panel.
