PS80 - Small 80W darlington amplifier
Hello friends.
After a long time without posting due to work and other problems I bring a new amplifier that is still being developed and tested.
The PS80 darlington series is a small amplifier with darlington transistors at the output for a very simple purpose: to push my bass.
Simulator tests (the circuit is not yet definitive) have shown excellent performance at high frequencies as well, but I will use it to push my bass speakers.
I will still manufacture the pcb, 'tune' the amplifier and after that do the test using a QA401 audio analyzer, from QuantAsylum to better see the behavior of THD, IMD and the like.
Here in Brazil as always very hot and with good music !!! Hugs
(Paulo from PHS Audio)
Follows the provisional and still pending adjustment of values
View attachment PS80-NOVO-OPEN.pdf
Nice design.
I used the TIP 147/TIP142 in a hybrid amp design myself. However, I coupled the output to the collectors rather than the emitters. This allowed me to add simple overcurrent sensing and limiting. I call this the "Tube Buffer". It has voltage gain of one. It requires a rail to rail voltage swing on the input which is quite easy to get with a tube preamp. The input Z is high enough I can couple a tube preamp with a relatively small capacitor. I did this primarily to save weight as it gets rid of the heavy tube output transformer. This performs well even without negative global feedback.
I once made a small Darlington stereo amplifier using cheap TIP100/105.
HERE. Yours is simple and elegant. Mine is ugly:warped: but I do recall that that amp sounded really sweet. It was a stepping stone towards my later models and it proved to me that Darlingtons can and do make great amplifiers.🙂
Looking back, I think I had too much time on my hands.🙄:xeye: :whazzat:
I made a Darlington amp once with conventional EF follower circuit (not HEC) and found that the Vbe multiplier has to account for the Tc of both output and driver since they are always at the same temperature and are cascade. So Vbe1 X Vbe2 should be compensated by a Darlington Vbe multiplier or bias won't track very well, can runaway. :hot: There are some suitable Darlington in TO-126 if you can get them.
