Ps1 Lcd?
i havent found the extension yet, but i did find out how much light the projector can should put out, im using a bell&howel 301 g ohp with a Eiko bulb. The bulb has a very warm color but hey it was free so itll work til it dies
i looked up the bulb and found out it gave off 17,000 Lumens
i also made a new screen out of blackout cloth and cheap wood for about 30 bucks so heres some pics
yeh it is sweet for what you pay, from about 7 feet away with a 56 inch projection the screendoor effect is noticable but once you start watching you forget it is there as the imae gets smaller or you move farther away it looks as good as a normal tv. On mine from about 10 feet away the 56 inch screen shows no screen door effect. And the lcd is good at video games sna andreas looked amazing. it is much better then i expected but i would recomend a bright light because mine gives 17000 lumens and the dark scenes are hard to see, unless you adjust the brightness on your dvd player. other than that i am very happy with it.
