No FETs in the amp?
Is the display inverted on the scope?
Long shots...
Pin 13 not at 5v?
Either pin 3 or 4 below ground?
Long shots...
Pin 13 not at 5v?
If what you're seeing on the scope is accurate, it's not normal. If it had FETs in the supply, I'd expect excessive current draw.
Did you check the things I listed?
- General Interest
- Car Audio
- Ps drive wave
