Hi Peeps. Just constructed my newely LCD, OHP Combo. Works rather nicely. The only problem I am having is that the lcd does this thing where it gets dim, them back bright again. Not fading to the point of going pitch black. But considerably enough to where you can notice. Anyone have any feed back on this?
Thanks.
Thanks.
what type of input source are you using. This may be a case of macrovision. This is a type of anti piracy that dims and brighten the images. happens alot with dvd players. it did with mine so i went to using a computer for playing dvds and fixed the problem.
I Also have another question. When I bring up the menu screen, What does the signel level mean? Does that have anything to do with brightness or contrast or anything?
i am not familiar with your panel's functions so i don't know what the signal menu means. What i would do is to hook up a tv or vcr signal to the panel and see if it dims in and out. or hook up the dvd --> vcr--> tv along with the panel such that the same signal is sent from the dvd to both at the same time. then see if the dimming occurs at the same time on the tv as well as the panel.
By the way, what kind of reponse time does your panel have? Any lag in fast motion scences?
Hmmm. I am not sure of what the response time is for my panel. But the only lag it seems to have, is when there are seens of muzzle flashes from guns. It gets that computery effect everytime there is gun fire. Other than that, the picture quality and response time seem to be truly awsome.
