Proxima Lightbook LB10—failing indicators?
I own a Proxima Lightbook LB10 (manual at http://www.projectorcentral.com/pdf/projector_manual_595.pdf)
I was having problems similar to an earlier post (http://www.diyaudio.com/forums/showthread.php?s=&threadid=49701&highlight=lightbook) so I switched the lamps wondering if that would help.
In the process however, something went wonky and now two indicators are flashing fast—which, according to the manual, means that the projector is not fully open.
It is, however, fully open. And fiddling with it's exact position does not make a whit of difference.
If anyone has suggestions save going to a repair shop please inform me.
Also, if you have alternative projector forums that I can search for more info, please let me know.
