I am a new member on this forum. I just bought an LCD panel from e-bay for the DIY LCD projector, its "Proxima data Display A342". I did not receive any documentation or cables with this panel. I will realy appriciate if someone can help me to figure out video pinout for this panel, so I can use this on my PC. The video connector type is a DB9 female.
DB9? That sounds like EGA or lower...
Is there a quality video signal that uses DB9? None that I'm familiar with, but I could be wrong.
--Clint
--Clint
I did try the EGA and CGA connections on this panel but I do not see any video on the panel. Any other advise will be helpful. Thanks.
DB9 VGA Connector
Many of the early VGA screens used a 9 pin iput on the monitor end. Especially the NEC multisync series etc. you could try to find one of these cables.
If you give me a week or so I'll hunt through my old files and find the pinout for you.
Rgds,
Brett
Rgds,
Brett
VGA DB9 Connector
DB9
PIN DESCRIPTION
1 Red Video
2 Green Video
3 Blue Video
4 Horizontal Sync
5 Vertical Sync
6 Red Ground
7 Green Ground
8 Blue Ground
9 Not Connected
D15
Pin Description
1 Red Video
2 Green Video
3 Blue Video
4 Monitor ID Bit 2 (Ground)
5 Ground
6 Red Return (Ground)
7 Green Return (Ground)
8 Blue Return (Ground)
9 Key (not used)
10 Sync Return (Ground)
11 Monitor ID Bit 0 (Ground)
12 Monitor ID Bit 1 (Not Used)
13 Horizontal Zync
14 Vertical Sync
15 Not Used
Good Luck ,
Brett
DB9
PIN DESCRIPTION
1 Red Video
2 Green Video
3 Blue Video
4 Horizontal Sync
5 Vertical Sync
6 Red Ground
7 Green Ground
8 Blue Ground
9 Not Connected
D15
Pin Description
1 Red Video
2 Green Video
3 Blue Video
5 Ground
9 Key (not used)
13 Horizontal Zync
14 Vertical Sync
15 Not Used
Good Luck ,
Brett
