Proview PL501b 15" 1024x768 LCD Monitor - $199
This monitor is $199 after rebate here.
Not sure about ribbon cables in the way.
Proview PL501b 15" 1024x768 .298mm LCD
15" screen size
15" viewable screen size Learn More
1024 x 768 resolution Learn More
0.298mm dot pitch Learn More
Frequency Range
Horizontal:30-60kHz
Vertical:60-75Hz
Screen Resolutions
1024 x 768
Video Input
Bandwidth:80 MHz
Contrast Ratio:350:1
Video: Analog RGB 0.7pp/75 ohms
Sync:Separate, TTL
Compatibility
PC and Mac
Power Requirement
AC 100-240 Volt 50/60Hz Adapter
Power Consumption
Max 40 W
Regulation Compliant
UL, CUL, FCC-B, DHHS, TUV/GS, CE, MPR-II/TCO99/BSMI/VCCI
Plug&Play: DDC 1/2B
Power Management
Meets Energy Star®, VESA® DPMS™, TCO '99 and Energy 2000 standards
Operation Condition
Temperature: 32 to 104F
Humidity: 20% to 80%
