MicroCenter has the Proview PL-513S 15" LCD for $209.99 with $60 in mail in rebates. This works out to $149.99 + Tax. Link rebate 1 rebate 2
The specs look respectable - I'm not sure anyone has tried to use this LCD - but for this price...
Viewable Size 15" viewable size
Interfaces 15-pin mini D-sub video interface
Pixel Pitch 0.297mm pixel pitch
Maximum Resolution 1024 x 768 @ 75 Hz maximum resolution
Image Brightness 250 cd/m2 image brightness
Image Contrast Ratio 400:1 image contrast ratio
Response Time 16ms typical response time
Horizontal Scan Range 30 KHz - 60 KHz horizontal scan range
Vertical Scan Range 60 Hz - 75 Hz vertical scan range
Maximum Viewing Angles Horizontal / Vertical 120° horizontal / 100° vertical maximum viewing angles
On-Screen Controls Brightness, Contrast ,H Position, V Position, H Size, Phase, Color Select , Auto Adjustment, Reset, Language, OSD Adjustment, Exit
Front Panel Controls Power ON/OFF, Digital four keys control panel controller
Dimensions (WxDxH) 13.54" x 6.54" x 13.11"
Weight 6 lbs.
Power Supply External power adapter
Voltage Required AC 100/240 V ( 50/60 Hz )
Power Consumption Operational ( Standby ) <36 Watts
Included Cables 1 video cable, and 1 power supply are included
Manufacturer Warranty 1 year limited warranty
Weight 6 lbs.
