PROVIEW CY-565 15' TFT LCD COLOR MONITOR
15.0" XVGA LCD TFT Active Matrix color monitor.
Display size 15.0" (304 x 228mm).
Dot pitch 0.297mm. Maximum resolution 1024x768.
Display colors 16,7M. OSD controls.
H-SYNC: 31-60KHz, V-SYNC: 60-75Hz.
Bandwidth: 80Mhz.
Contrast Ratio 250:1. Brightness 200cd/m2.
View angle: 40/50° vertically & 60/60° horizontally.
DDC1/2B Win PnP. DPMS Power Management.
Approvals: UL, CSA, FCC, CE, VCCI.
2W+2W multimedia speakers.
Is that any good?Has anyone tried it?I can not find the time response spec!
The price is about 320$.
Bandwidth: 80Mhz.
i think its very expensive for a "low" contrast ratio tft. try searching a 350:1 CR or better, you can buy one for ~ 220$
regards,
gone
regards,
gone
That's a terrible deal. The NEC 1545 is $100 less, has a much better contrast ratio, and is known that the V and H boards can be seperated.
Ok then!Forget that panel!I must buy a 15" soon because my setup now has a 6" 320X240 tft tv and the pixels are very big after 50" diagonal!
This pic was taken with the lights on.It is 70" diagonal and the pixels can be seen a lot.At the foto you can not see them very much but they are there!
