Hello
New to forums and this is my first post
Picked up for free a Proton D540, issue is left channel works but with very low output. Right channel works fine and sounds great. Possible speaker relay issue or volume pot issue? If relay, any possible replacement suggestions. Applied contact cleaner to all pots with no luck. Any help or suggestions would be greatly appreciated. Thank you
Hi Digitalcreep,
Welcome to DIYAudio!
I really wish you hadn't started with control cleaner. That stuff removes lubricants as well, and most people pump the control really full.
Is that channel low on all inputs? It could be a relay or a switch contact. The relay should be replaced with the same kind. Look at Mouser and Digikey for relays.
-Chris
-Chris
Hi Digitalcreep,
Try the main in with another preamp. Don't stick a line level signal in there! Also, it could just be a poor connection in the loops. Clean the ends of your loops and try it again.
I'm glad you used a small amount of cleaner. It doesn't take much to do the job normally.
-Chris
-Chris
