Proton AM2 issue
Hi, everyone.
Hope this is the right place to ask..
I own this nice little amp with a problem that, while playing, one, or the other channel, shut off.
I was able to trace the problem to the input connectors. With the cover off, gentle bending the back panel, the sound reprise.
Is a known issue of these units? Defected PC trace, cold solder?
Thanks in advance for any tip.
Solder joints under repeated movement can fatigue and crack - but so can the PCB traces, so
examination with a lens is worth doing to see if any definite cracking can be seen - if a trace is cracked or the pcb itself is cracked a repair is needed. But if lucky its just the solder.
