Protection
That changes things... to some degree. I was mistaken about the type of board. I assumed that there was a 21844 under one of the heatsinks.
The attached circuit is likely what you have.
Do you see any transistors near the shunt resistors?
  • AQ1200_SCHprotectionmarkedtype7-01.pdf
Look for narrow traces leading away from the shunts. If there are any, do they lead to a group of components that include a transistor. You're looking for the equivalent of Q288 on the AQ1200 diagram.
Look for this for both sets of shunt resistors. In the AQ1200 diagram, they show only one circuit/shunt-group but sometimes, there are two independent circuits.
