Hi all,
does anybody know if there are protection diodes on the current-outputs
of the DSD/PCM-1792/94-DACs like in the PCM-1702/04-family?
Might be a nice information, when playing around
with non-OP I/V-stages.
Regards.
Regards.
Der Dude said:Hi all,
Regards.
No clue. Asking the manufacturer won't help, they never responded to any of my Emails. We'd possible have to measure it.
Probably doesn't matter.. Depending on the internal architecture of the dac monotonicity suffers badly if there is more than a few mV of signal present on the current outputs of the dacs. Any I/V converter should probably keep that point within a mV of ac ground anyway.
Kevin
Kevin
kevinkr said:Probably doesn't matter.. Depending on the internal architecture of the dac monotonicity suffers badly if there is more than a few mV of signal present on the current outputs of the dacs. Any I/V converter should probably keep that point within a mV of ac ground anyway.
Kevin
Hi
Yes, this requires < 1 ohm transfer impedance. The output of most "current output" DACs isn't that high, e.g PCM63 is 700 ohm.
cheers
I have used the DSD 1792 similar to PCM 1792 and with open output it goes close to 5V so it seems like there is no protection.
I have used it with a 47ohm resistor on the output without any problems. As i remember it there is a offset of the current so it goes between 2 and 10 mA where 6mA is zero.
Kind regards
Ole
Kind regards
Ole
