Protection C when using active crossovers?
Yes; that's indeed what I said. Good of you to repeat it; I agree.
This is what you said:
Especially important if there's a resonance well below the crossover frequency, as with some compression drivers. My TD-2002s have a resonance at 400Hz, yet are crossed at 800Hz. A series cap will introduce reactance right where good damping is needed.
Low frequency resonance of driver that is stimulated by signals that have passed from active crossover, through amplifier, through (useless) protection capacitor, produces back EMF that sees (useless) protection cap, which will partially pass EMF from driver back to amplifier, and (useless) cap will reflect remainder back again to voice coil. I say useless, because the bigger the cap, the less protection it offers from crossover failure, or operator error. The smaller the cap, the more defeats purpose of active crossover.
Many IM difference components generated by driver are much lower than driver resonance and again, big useless protection cap in circuit gets in way of amplifier's damping capabilities.
What if a cap value at the turn over frequency was inserted in the speaker feed?
That is one passive pole.
Then add another passive pole, at the same turn over frequency, to the input of the Treble amplifier.
Those together give roughly a 2pole attenuation of a wrong signal and may just about protect an expensive driver from damage.
They also give 2poles of a complex multi-pole roll off.
The active feed from the DCX is now two poles less.
I officially give up.
No need to give up. No need for cap. Just good operating procedure, and amplifiers with high damping factor (low output impedance).
Exactly why fpitas and I pulled the capacitors out of our actively crossed systems 😉.
He "gave up" on explaining that to you, because you don't seem to get that he removed his capacitors because they lessened the damping available from the amplifier.
