Pros/Cons Remote Power Supply
Connectors
Any suggestions as to what and where to get for DC power entry receptacles and plugs for connecting the amp and PSU? I would like to use 3 connectors ideally.
I do not want to use normal AC plugs and receptacles just in case someone may make the mistake to plug the amp using the A/C line from the wall:bigeyes:
I need high rated DC amps as well, any suggestions are welcome.
Thanks,
Chris
Amphenol also makes high quality connectors that are dust proof and also "keyed" so you can not connect them improperly
