Pros and cons of various RIAA Network topologies
There are a wide range from different kinds of RIAA equalizer networks. I am looking not for such networks with the use of coils - only caps and resistors - go to
https://www.google.de/search?q=riaa...Cqf_ygPzsIEI&ved=0CAcQ_AUoAQ&biw=1280&bih=857
for finding most of all the exist versions.
From the last there are two basically kinds:
1) RIAA preamp with passive network between two line amps
2) RIAA preamp with NFB RIAA network and one oprerational OP-Amp as IC or as discrete solution
But there are a wide range of mixtures from both of them (actually two passive 6db low pass filter with different cut-off frequencies) - most with two independent gain stages.
I want to have a list with short form explanation regarded the pros and cons of all often used topologies.
Where I can find this online or in a suited amplifier book?
I am looking to those topology with best sound, and not with lowest possible noise, because the residual noise from the records is still present (in opposite by a use of microphone at similar preamps).
This URLs are of interest:
http://www.tubecad.com/2007/09/blog0120.htm
http://www.tubecad.com/articles_2002/RIAA_Preamps_Part_1/RIAA_Preamps_Part_1.pdf
http://www.tubecad.com/articles_2002/RIAA_Preamps_Part_2/RIAA_Preamps_Part_2.pdf
but without pros and cons.
Thank you very much for advices.
Hmmm sure looks like a Large pile 'o parts.
What ever happened to the Simple Few/minimal parts designs?
From my small experiences the rate of diminishing returns in Vinyl playback hits Early and Hard.
With Many of the exotic claims in:
TT's, Carts and Phono stages being Very difficult to hear.
Daresay even bordering on illusory... in some cases ;)
Yesss...I know it's a hobby .
When splitting the riaa in two sections. you can use tubes with lower gain and lower microphonics.
To make life easier, opamps, passive networks and MM carts, you can make life a bit easier if you derive some of the T5 compensation from the loading resistor and the self-inductance of the cartridge. (The issue with opamps is that they run out of gain on peak material above a few kHz where the cartridge output can exceed 8mV.) Bob Cordell did a great job explaining in his VinylTrak phono pre in Linear Audio Volume 4.
