Projects for next hollidays (the world smallest VBITNGC??)
... we don't sleep, just a little delay, because I had to build and enjoy my latest phonoclone :D
Here, this is an actual picture from my workbench: Analyzing the circuit again, measure the enclosure, holes etc. to finish the documentation.
Coming very soon in this theater.
Franz
/Edit: BTW, this little amp was working for more than half a year in a friends apartement. And this friend is very unhappy and unpatiently now, as he has to use his Sony surround system :bawling:
Here we go: first step, the partslist (I attach an excel sheet, zipped).
Mini Tube buffered GC
PSU enclosure
Amp enclosure
Chinch connectors 2
Speaker-Connections 4
230V Connector incl. Filter and switch 1
Volume Knob 1
Heathsinks 1
Tube socket noval 17.5mm dia 1
Screws etc. 1
Wires, Cables, shrink tubes 1
Torroidal 2x25V 225VA 1
Trafo 2x18V 1.5VA 2
Trafo 6V 2VA 1
PSU
PCB 1
9 pin D-sub (female) 1
Fuseholder 1
Relais 6V 1
Dioden 60V/6A MUR860 8
Dioden 100V/1A IXYS 1-16D 2
Rectifier 10V/400mA 1
NE555 1
LM317 1
LED blue 1
10000uF / 35V 2
1000uF / 35V low ESR 2
1000uF / 63V opt. 100V (low ESR) 2
470uF / 63V opt 100V (low ESR) 2
4700uF / 16V 1
47uF / 16V 1
10uF / 16V 1
1uF / 63V 3
1uF / 63V opt 100V 2
0.1uF / 63V 3
0.1uF / 63V (opt, Diode bypass) 8
200K Trimmer liegend 1
4.7K Spindeltrimmer (oben) 1
33K 2W 4
100R 2W 2
1R 0.4W 2
200R 0.4W 1% 1
3.3K 2W 1
100K 0.4W 1
Amplifier
Main PCB 1
Tube PCB 1
E88CC 1
LM3875TF 2
50K log Poti stereo 1
330uF / 35V low ESR 4
10K 2W 2
180R 0.4W 1% 2
3.3K 0.4W 2
18K 0.4W 1% 6
47K 0.4W 1% 2
0.1uF MKP 60V 4
Franz
  • partslist.zip
I just added an updated excel sheet, containing the parts-numbering as printed on the psu-pcb.
The parts for the amps board are not numbered, but printed by their value on the boards.
Digi: did you draw any schematics in the meantime? We never had a schematic from the psu, we just worked with the print :)
Franz
  • partslist.zip
gemby said:
Digi, is it still posible to order boards? Any other payment method except paypal?
drop me a mail for service:)
I like pp,it is fast and easy.west union or cash order is accepted at the same time.
Evilsizer said:
damn... i havent seen this thread for a while... maybe we can hope they have some extra boards.
We will start a main components group purchase(enclosure,rs232 lockable,relay,alps16..etc).
if there are enough interest,I will make round 2 pcb set gp.
kind rgds
Zang
kind rgds
Zang
Hi Zang, i just dropped you an email, btw, i am interested for buying kit, or main komponets group by, whatever....what will kit include? It will be very nice if it will include tube, pot, IC, socket, enclosure.....it will be perfect :)
