Can the projected image size be adjusted on your ohp or lcd panel or does this depend on how far away you move it from the wall cause the thing is i am able to get a 73" by 48" screen by using the crappy 100" tv thing with a fresnel and have ordered a viewframe spectra c lcd panel with a ohp with a 400 watt bulb and I would like to keep this same screen size when i get the lcd setup up and running also my room is square 11ft by 11ft will this be enough can anyone give me sum advice.
cheers.
cheers.
