I make simulation with WinISD to lots of the drivers in this website and also I check and Eighteensound drivers!
Eighteen Sound 15MB606 - 15" Mid Bass
They have files for winisd and this make thing faster.
Pls do yourself a favor and either go and grasp the art of loudspeaker design (including the more technical issues) or build a proven design like some of us suggested. You'll have to have a clue about efficiency, max power load, directivity, distortion, all related to frequency vs (desired) level. You'll also have to understand how to measure sound output. And some knowledge about crossovers, active or passive. Among a ton of other things.
Which horn will you use?
Can you take acoustic measurements?
Do you have experience in x-over design?
Why such a large woofer when there is also a subwoofer?
I will use all with different amp and also i have Behringer DCX2496.
For the horn I still not sure, probably SEOS-12.
I don't know how to make passive x-over, but when i will play them with different amp, I know what to do with the DSP, but maybe will need something just for protection of the twitter!
Why not 15 inch wofer and sub will go more down.
I measured speakers which i have in the moment with regular mic, but I ordered Umik-1 before one week and i hope it will come today to see what will be the difference.
I have in the moment speakers which I made by design of Zaph, they sound good but im not happy, I want to be by me.Pls do yourself a favor and either go and grasp the art of loudspeaker design (including the more technical issues) or build a proven design like some of us suggested. You'll have to have a clue about efficiency, max power load, directivity, distortion, all related to frequency vs (desired) level. You'll also have to understand how to measure sound output. And some knowledge about crossovers, active or passive. Among a ton of other things.
I wanted that too, about 35 years ago. Best thing that happened next was that I eventually got access to measuring equipment (Neutrik 3300 FWIM) and in-between read a lot of books and publications (no www then). Only then I could start making proper designs I could be more or less proud of.
For now I just read and I have only Umic 1, but probably will buy more 🙂I wanted that too, about 35 years ago. Best thing that happened next was that I eventually got access to measuring equipment (Neutrik 3300 FWIM) and in-between read a lot of books and publications (no www then). Only then I could start making proper designs I could be more or less proud of.
I want just to confirm with you for the protection from the amp, just for case of pop to protect the BMS 4550, 30 mf capacitor its ok?
I plan to make active crossover around 850 or 900.
I already buy BMS 4550 in 8 ohm.
My English is not very good, but I will try to read and understand the book, thank you30 will do. And for reading: give Vance Dickason a go.
- Project with high power
