SMPS
Hi dears
Look that!!
It´s a Rod Elliott design that I build.
http://i129.photobucket.com/albums/p220/sachserjuris/SMPS.jpg
http://i129.photobucket.com/albums/p220/sachserjuris/SMPS2.jpg
http://i129.photobucket.com/albums/p220/sachserjuris/PWM.jpg
http://i129.photobucket.com/albums/p220/sachserjuris/powers009.jpg
this last is with the power amplifier and SG3524 pwm circuit together.
Any questions...(++++++++++)
Hi dears
Look that!!
here is my SMPS for the car sub amp i made
just basic (ESP) design overbuild with 8x (irf540 28A) fets - double discrete rectifier with ultrafast 1000v diodes (MUR8100E) - the usual SG3525 controler - lots of 105C caps and frond and back chokes for filtering - handmade tranny potted with superglue - perforated board constraction with very fat solder tracks and fat cabling - 50Khz operating frequency - dc output +/- 60volts
very pleased with the outcome .
smps exibits some hi frequency harmonics in the 10-15 Mhz region wich does not affect itself or amplifier . and didnot bother to filter more . 6 months in car use driving an overbuilt "A.Holton N-channel amp" with a 4ohm JBL P1220 400Wrms SPL woofer easily up to its x-max with no distortion proved power capability and stability .
I'm not sure this helps, but maybe he's talking about this:
http://www.eproje.com/modules.php?name=News&file=article&sid=569
yes, it is correct, if you need help, ý can help to you everything for it,,
- General Interest
- Car Audio
- project smps for car
